Temp. Sensitive Antenna?
Old Dec 14, 2007 | 12:57 PM
SnowBuggy's Avatar
Angry Temp. Sensitive Antenna?
If the temperature is below ~20 deg. F. I get a "no signal" message on the radio. If the truck is warmed up inside and it is not moving for a few minutes I get signal. This is the Ford radio that came in the truck. This only happens when in Sirius (aux.) mode. Otherwise the AM & FM work OK.
Do I have a bad satelite antenna?
Old Apr 12, 2012 | 02:58 PM
SnowBuggy's Avatar
Better late than never to update what I found. Bad battery. Probably from truck setting on the lot for a long time. New, larger, battery solved the problem.
Old Apr 14, 2012 | 09:24 PM
ericbc7's Avatar
Thanks for the update !
