Siruis Antenna Install
I just installed my sirius ant on the dash all the way up to the windshield and just to the right of the security light. I didn't have time to finish my wiring last night but I'll let you know how it works.
I tried the dash location and got excessive drop outs there. Put it on the roof and it was better then tried a visteon antenna on the roof and worked the best so far. I moved the visteon to the dash and it was back to bad. I'm going to try under the cowl with the visteon and see if its as good as the roof. The original antenna was the one with the sir-ecl kit.
Originally Posted by LittleTow
Hi Folks - Has anyone done the stealth antenna install on a 2003? I see by the member profiles that some of you have different year trucks but all of the install pics/procedures show an 04. I "assume" its a similar procedure for the older models but would like to hear from anyone whos done it on 03, etc.
Thanks!
Thanks!
https://www.f150online.com/forums/sh...d.php?t=121890
I moved mine t on top of the cowl. I originally had it under, but had some reception problems. Haven't had any on top.
Just used 3m moulding tape. Hasn't budged in a year and a half.
Regards!
Regards!
