Seriously Sirius
Seriously Sirius
Well, it's done. I just finished installing the antenae and running the wires for the Starmate Replay. I went in thru the 3rd brakelight, popped out the grommet, ran it along the back of the headliner to the weather stripping on the side, took that all the way down the front of the door to under the dash and across. Came out thru the cup holder. Gotta find a good mounting bracket, I'm not thrilled with the options I currently have...
TIME TO ROCK!!!!!
BTW - Boom box for the Starmate Replay is due out this month. Pics don't look bad!
TIME TO ROCK!!!!!
TIME TO ROCK!!!!!
TIME TO ROCK!!!!!
i mad a simple bracket form .050 piece of aluminum that mounts from the 2 bolts that hold the tray in the top of the dash. it sticks up from behind the dash bout an inch then my starmate moutns right to the bracket. my wires also come out at the top where the bracket does, works great and no messy wires all over the place.
i'll try and take a pic, but not sure how to post them on here.
on
Originally Posted by expy03
Rockpick,
What holds the mount in? Friction, or did you have to remove the trim piece?
They are nice brackets, I had one in my '01, got one for my '06, and jsut did a GPS mount in my mom's van with one.
If you ever had a Hertz car with never lost, they use the Pro Fit brackets all the time for mounting the head units.
Thanks for the help guys. I like the one RP has, unfortunately they don't make that for an '01...
Originally Posted by RockPick
They do, however, make a different VSM model for the 01...HERE'S A LINK -- GOES TO A PDF
Originally Posted by Krohbar
I'll have to 2nd the pro-fit. I've got one for my Clarion. I flipped it, installed it on the other side though...
I have a cradle that uses suction mount for it currently and the thing is a PITA - these mounts look much better!
Thanks guys
