roady mount in a 98
Old Nov 3, 2005 | 08:00 PM
98lariat4x4's Avatar
roady mount in a 98
I bought my wife an XM for her Bday and it came with a "free" roady. I thought I would install the roady into my 98 but I don't want it ghetto. I would like a bent metal bracket and I would like to hard wire it for power and sound. My head unit is the factory one and I have the 6 disc changer behind me in the left panel. Its a 98 so its a 3 door cab, the part behind the driver's door does not open on my year.
So, can someone point me in the right direction to hard wire this thing?
How do I run the antenna?
Old Nov 10, 2005 | 09:44 PM
my98f250's Avatar
sirius install
hello 98 lariat4x4 i too have a 98 mine is an f250 l/d and i am using the sportster replay!!! i ran my antenna up front center of the windshieldand tucked in into the horizontal rubber along the top around the corner and down the driver side post under the plastic cowl in to the engine compartment and threw the firewall via the throttle cable grommet i use the cig adapter for now and the suction cup thing i drilled two small holes than i removed the black plastic heater cover drilled matching holes in that i used two small holes with mollys and it fits nice i can see it well and work it with the remote that comes with it!!! i am using the internal f/m transmitter and it works great i will eventually hard wire the the power plug so i dont have to leave the cover open i live in north jersey and reception is great i love it!!! hope you enjoy yours as well!!!! good luck !!!!!!!
