No keys
Purchased a salvage 1998 F 150 for reconstruction and use on the farm. I have NO keys and after reading the posts re. P.A.T.S. I conclude that I most likey have the P.A.T.S. 1 system. I need to unlock the steering in order to move the truck around in the shop and ultimately I need to start the engine. All inputs are appreciated. Thanks
I would say you'd have to go to a dealer your the VIN and proof of ownership, or bring it in on a rollback. They should be able to make you one. It wont be cheap though.
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
My Home Page
agmantoo,
Read the posts carefully.
'98 F-150's do NOT have P.A.T.S.
Call your local locksmith.
98 F-150 XLT 4X4 ORP Super Cab Short Bed, 4.6, Auto. Superchip, Gibson sing. cat-back, Airaid, 80/100w German head lamps. Warn HS9500i winch with semi hidden mount. Wrangler dual battery kit with red & yellow top Optima batteries. Torsion bars cranked up 2 turns. Needs one more door and a lot more power. I think I need to talk to Mr. Whipple.
[This message has been edited by 98fword (edited 06-11-2000).]
Thanks 98fword, I have reread your 7-22-99 post more thoroughly and I was reading something into the post that did not exist. Your efforts and knowledge to generate the information is most appreciated. Since I have some information such as vin number and a computer build sheet (found under seat) is it possible for a locksmith to make a key without having to travel to my farm? What does a dealer need to generate a key? Thanks a million.
So, have a local dealership find out the dealership it was purchased from and call them with your vin number. They should be able to pull it up on their computer and give you the key code. They could even cut you a key just from the key code. You'll never even have to go to a locksmith. Or, once you have the code, you could just go to a locksmith.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Ford hvy dty rubber floor mats, Kenwood 10-disk cd changer, Kenwood am/fm cassette head unit, Ford bugshield, Chrome Grizzly Wrap Around Push Bar with 2 KC 100w Daylighters, Lund Lunar Visor, Ventshades, Ford bedliner, Lund Premier tonneau cover, cab and bed professionally undercoated, Code Alarm Sure Start RVS remote starter, Ford alarm, Realistic CB with Wilson Little Wil antenna, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
I HAVE KEYS! Thanks to all that helped. Kind of used a combination of inputs and got the key code and went to the local Ford dealer. Believe it or not, They made two keys as a courtesy. No fee!
agmantoo,
You must not be one a 'em 'er feriners!
(Anyone born further north than Winston-Salem)
We like to take care a r own. Know wut I mean?
