running the 1/4
A couple quick questions....
1. When running your truck, do you remove your tail gate to reduse waight? Or is the areodinamic more important.
2. Is there anything else that can be removed to to lighten the truck to reduse time, outher then subs, spare tire, and maybe the tailgate.
HI!... If your running slicks or drag radials then lose the tailgate. It weighs about 48LBS on a stepside. Spare tire is about 48LBS depending on tire size and make. Trailer hitch is good for about 44LBS. Remove your front sway bar. It allows your front suspension to come up farther and faster to transfer more weight to the rear wheels upon launch. It weighs about 22LBS. Fold your two huge side mirrors in when running. I gain 1MPH in the trap speed everytime I fold them on my F-150. If you have a 60/40 bench seat then you can remove the passenger's seat. It's about 60LBS I believe. Not sure on that one, I ordered my truck with bucket seats. Jack your tire pressure up to about 40-45PSI in the front tires. This creates less rolling resistance. Run with a bit more that 1/4 tank of fuel. Fuel is heavy.
Originally Posted by built54
Neal, you have it down! never thought of taking the front sway bar out
and ill be running my goodyear eagle II's 285-60-16 i dont have slicks or drag raidles, i was thinking i would run like you said 40-45psi in the front and 20-25 in the rear, sound about right?
street tires, keep them at the correct pressure, anything lower is just a drag. 14.3???? I Dunno about that
HI!... Ya if your running street tires then don't go below 28psi. I hope you run faster than 15.5E.T. My bone stock 07 RANGER with 4.0L ran 15.58E.T completely BONE STOCK. Good luck on your runs.
Follow what Neal has said...
The only thing I disagree about is the street tire debate. My 295/45/18, I lower to about 23-25 PSI.. Anything over 30 and I just spin, spin, spin.. It's a street tire. It depends on the tire..
so do i want to remove my front sway bar? Would it help my that much?
Plus, it's weight removed..
Originally Posted by JeremyGSU
I ran it as is because I wanted to see how fast it was as I run it on the street. Full spare, crap in the bed, and a few things in the truck. Needless to say it was slow.
