I've started to get this warning when I visit the site. I'm not sure if this is an error on the sites end or something on mine, but figured I'd pass it along.
You will NOT get that warning if you are using http://www.f150online.com. You WILL get it if you are using https://www.f150online.com. The site is not set up for secure browsing.
You either have some malware and/or your IE settings need to be changed. What version of Windows and IE are you using? Or is that Windows 10 and Edge?
I had tried it both ways and got that warning each time I tried. I reset IE to default and it's back to normal. Something changed but now it's ok again.
That's exactly what I was going to suggest - set IE to defaults - I just wanted to confirm your versions first. I would still recommend you check for malware.
