When is the Photo Gallery going to be fixed?
Originally Posted by Cars2007
Paste the error message you get into this thread and I'll take a look.
EXCEPTION INFO
Exception overview
Error message: The variable "client.gallery_id" is not defined!
Error type: expression
File: /opt/tomcat6/webapps/ROOT/galleries/admin/photodefine.cfm
Row: 37
Column: 4
Program code
35 </script>
36
37 <CFQUERY DATASOURCE = "f150galleries" NAME = "qGetAlbum">
38 SELECT album_id, album_label
39 FROM album_t
Stack trace
[Error message: The variable "client.gallery_id" is not defined!]
com.youngculture.smith.engine.cfutil.SmithStruct.g etVar(Unknown Source)
__smithdynamic._var._www._html._f150online._htdocs ._galleries._admin._photodefine.execute(_photodefi ne.java:71)
com.youngculture.smith.engine.pages.CfPage.run(Unk nown Source)
com.youngculture.smith.engine.pages.PageUtil.runPa ge(Unknown Source)
com.youngculture.smith.engine.util.PageDispatcher. includePage(Unknown Source)
com.youngculture.smith.engine.servlets.SmithServle t.serviceRequest(Unknown Source)
com.youngculture.smith.engine.servlets.SmithServle t.service(Unknown Source)
javax.servlet.http.HttpServlet.service(HttpServlet .java:803)
org.apache.catalina.core.ApplicationFilterChain.in ternalDoFilter(ApplicationFilterChain.java:290)
org.apache.catalina.core.ApplicationFilterChain.do Filter(ApplicationFilterChain.java:206)
org.apache.catalina.core.StandardWrapperValve.invo ke(StandardWrapperValve.java:233)
org.apache.catalina.core.StandardContextValve.invo ke(StandardContextValve.java:175)
org.apache.catalina.core.StandardHostValve.invoke( StandardHostValve.java:128)
org.apache.catalina.valves.ErrorReportValve.invoke (ErrorReportValve.java:102)
org.apache.catalina.core.StandardEngineValve.invok e(StandardEngineValve.java:109)
org.apache.catalina.connector.CoyoteAdapter.servic e(CoyoteAdapter.java:263)
org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyo teHandler.java:190)
org.apache.jk.common.HandlerRequest.invoke(Handler Request.java:283)
org.apache.jk.common.ChannelSocket.invoke(ChannelS ocket.java:767)
org.apache.jk.common.ChannelSocket.processConnecti on(ChannelSocket.java:697)
org.apache.jk.common.ChannelSocket$SocketConnectio n.runIt(ChannelSocket.java:889)
org.apache.tomcat.util.threads.ThreadPool$ControlR unnable.run(ThreadPool.java:690)
java.lang.Thread.run(Thread.java:619)
Exception overview
Row: 37
Column: 4
Program code
35 </script>
36
39 FROM album_t
Stack trace
I just received this one when I try to change the picture order in my gallery.
EXCEPTION INFO
Exception overview
Error message: The client scope is not enabled! Use CFAPPLICATION tag to enable it.
Error type: security
File: /opt/tomcat6/webapps/ROOT/galleries/admin/orderview.cfm
Row: 6
Column: 4
Program code
4 </CFIF>
5
6 <CFQUERY DATASOURCE = "f150galleries" NAME = "getpics">
7 SELECT photo_filename, photo_label, photo_thumb, photo_id, photo_order
8 FROM photo_t
Stack trace
[Error message: The client scope is not enabled! Use CFAPPLICATION tag to enable it.]
com.youngculture.smith.engine.cfutil.scopes.Client Scope.checkAcess(Unknown Source)
com.youngculture.smith.engine.cfutil.scopes.Client Scope.get(Unknown Source)
com.youngculture.smith.engine.cfutil.SmithStruct.g etElement(Unknown Source)
com.youngculture.smith.engine.cfutil.SmithStruct._ getVar(Unknown Source)
__smithdynamic._var._www._html._f150online._htdocs ._galleries._admin._orderview.execute(_orderview.j ava:28)
Everything else works , I just have a problem trying to move them around.
EXCEPTION INFO
Exception overview
Row: 6
Column: 4
Program code
4 </CFIF>
5
8 FROM photo_t
Stack trace
Originally Posted by Stealth
So what was wrong with how things were before the migration? Everything worked fine. You know, if it ain't broke........
A multi-machine license for ColdFusion MX is somewhere around $8,000. (Per CPU, as I recall - so around $16,000 for two servers, $24,000 for 3, and so on.) That was out of the question. There is another product called BlueDragon, which is cheaper, but still thousands of dollars if we wanted to use it on 2 or more CPUs (with another charge every time we added a machine to the pool.) In both cases we would have been looking at potential code changes anyway, since the gallery was written under ColdFusion 5. BlueDragon is CF 6 (or newer) and CF MX is in version 8.
In the end, I decided to go with the open source CF engine and do whatever porting / bugfixing was required to get it running.
Originally Posted by whitecrystal1
Here's the error given
I get this message when i tried to add photos
EXCEPTION INFO
Exception overview
Row: 37
Column: 4
Program code
35 </script>
36
39 FROM album_t
Stack trace
Please help, Cars2007 I really dont know how this works.
EXCEPTION INFO
Exception overview
Row: 37
Column: 4
Program code
35 </script>
36
39 FROM album_t
Stack trace
Ok,
Here is my picture story.
I spent ALL day trying to update my galleries. I would load pics, label them, write decriptions just so that on the final load deal, I would get the error messages and it would not load. Then, I start over. Sometimes it takes the pics but not the text. So, re-type it all. I have almost got it all completed after fighting and cussing it all day but then tonight I go in to "change order" on a couple of the galleries and it throws up another page of error crap. It now wont let me "edit" or "chage labels" or "chane order" or anything. By reading these posts from a month back this does not seem like a new deal but I cannot believe how difficult it has become. I have been away from here for awhile....wow.
Originally Posted by Lightguy
Ok,
Cars2007 has explained what's going on above. It has also been posted to copy and paste the error your receiving into this thread so that it may be corrected. You haven't done so..?
This is a free to join site that has many advantages in becoming a member. The administer is working with us on the problems and after his explanation as to why these errors are occurring, it's understandable.
I suggest you read from the beginning of this thread and follow direction to correct the issues you are having. It worked for me.
Very well. I had posted the error somewhere else on the site in this conversation but I did not here.
This morning I am getting the following error when trying to re-arrange numbering
Row: 6
Column: 4
Program code
4 </CFIF>
5
8 FROM photo_t
Stack trace
__smithdynamic._var._www._html._f150online._htdocs ._galleries._admin._orderview.execute(_orderview.j ava:35)
Row: 6
Column: 4
Program code
4 </CFIF>
5
8 FROM photo_t
Stack trace
Lightguy's report might be an indicator that the app needs to have session stickyness turned on at the load balancer. I have opened a ticket to get this done. The ticket probably won't get picked up today, but I set it to high priority so hopefully it will get done within the next few days.
This is a problem that arises sometimes when an application that was hosted on one server is switched to being hosted on more than one. Load balancers work by sending connections to different machines. If you start a session on machine A and the load balancer then decides to send you to machine B, and machine B doesn't know about your session, it will cause this problem. "Sticky" sessions instruct the load balancer to always send a visitor to the same machine.
Hopefully that will solve it. If not, I will continue to investigate.
So do i have to have a certin number of posts in order to make an album? I wouldnt think so but i figured i would ask because this is the error i am getting when i try to make an album
File: /opt/tomcat6/webapps/ROOT/galleries/admin/albumdefine.cfm
Stack trace
__smithdynamic._var._www._html._f150online._htdocs ._galleries._admin._albumdefine.execute(_albumdefi ne.java:24)
Stack trace
The load balancer setting I mentioned above hasn't been switched yet, I will see if we can get it expedited.
Here's my problem
Row: 37
Column: 4
Program code
35 </script>
36
39 FROM album_t
Stack trace
Row: 37
Column: 4
Program code
35 </script>
36
39 FROM album_t
Stack trace
