Question about sigs
Old Jan 9, 2007 | 01:30 AM
Hankmobile's Avatar
Question about sigs
I hate this weird bulletin board coding. Is there anyway to make html work? Or... how can I code my signature to be in the center and link to my gallery with this easycode stuff?
Old Jan 9, 2007 | 06:36 PM
GordoPanocho's Avatar
Registered User
Well, get used to it because fewer and fewer forums will allow HTML. That, and vB coding is easier for the masses. Not everyone can figure out the more complicated HTML.
https://www.f150online.com/forums/fa..._special_codes
While this vB page says we can center, use HTML, etc., there are several things that just aren't turned on and/or won't work here. For example, we cannot center text. But, adding a link to your gallery is easy. Try the following ... but without the ** characters. If I didn't have those in there, you'd just see your image ... and not the code.
[**url=https://www.f150online.com/galleries/mygallery.cfm?gnum=8825][**img]https://www.f150online.com/galleries/images/8825-12592-178333.jpg[/img][/url]
Also, check out the following posts on how to get the camera icon in the upper corner of your thread post profile info ... which will be a direct link to your gallery.
https://www.f150online.com/forums/sh...d.php?t=249297
https://www.f150online.com/forums/sh...d.php?t=208707
Good luck and post back when you're done so we can check your progress.
Old Jan 12, 2007 | 08:05 PM
Registered User
In updating my signature tonight, I found that you can use the [*INDENT] (sans *) vB code to move your signature over. Doing this a few times might be about right for centering your signature. It's worth playing around with. The image for my signature begins just a few pixels over from the first part of the image you can see. I've indented it once to get it moved over about 40 pixels. Give it a try ... and good luck.
Old Jan 12, 2007 | 09:26 PM
Hankmobile's Avatar
Thanks!! I'll have to play around with it some!
Old Jan 12, 2007 | 10:27 PM
Rockpick's Avatar
Moderator &
Gordo... thanks for the resize... much appreciated.
