will someone help me put a sig on?
Old Jan 5, 2004 | 12:24 AM
00white_lightning00's Avatar
I made a sig but was wondering how to install it. I tried going to the search button and got some good stuff but none of it seems to work. Tride to copy and past it to the sig box in the usercp.
help plz.....
Old Jan 5, 2004 | 12:37 AM
Silver_2000's Avatar
look in the questions about the site forum for info on how to post a picture and then just use those steps in your sig....
Doug
kobiashi's Avatar
make sure that the image you made for your siganture is located in a place where it can be accessed over teh net....
say on image station, or on the f150 online gallery here.
then go to "user cp" button above
then go to edit profile
in the field for your signature you will enter the image location just as you would insert an image in a post...
start with
[img]
followed by the address where the image is located
followed by [/img]
for example
"[img] http://www.whatever the address of the imageislocated.com.jpg [/img]"
(however, with no spaces between the address and the brackets)
hope that helps
Old Jan 5, 2004 | 12:41 AM
MaxTorque02's Avatar
Re: will someone help me put a sig on?
help plz.....
You need to upload your signature picture into your gallery first. Once it's uploaded, then you need to open it up. Then right click on the signature picture and look where it says properties. Copy the properties address. Now open up your user cp by clicking on the button towards the top. Click on edit profile. Go to the box at the bottom for your signature and paste the picture in the box. Besure to put [img] at the front of the address, and then put [/img] at the end of the address. This should show your signature picture in every post you make. It will look something like this:
[img]properties address from picture[ /img]
I purposely left a space between [ and the / so it wouldn't try and post a pic. Do not leave a space.
Old Jan 5, 2004 | 12:42 AM
Thanks, ill give it a try.
Old Jan 5, 2004 | 01:03 AM
work
Old Jan 5, 2004 | 01:05 AM
Old Jan 5, 2004 | 01:09 AM
Thanks maxtorque and everone else.
