What Is A Signature
If you look at the upper right hand side you will see 7 brown/tan colored icons. The first one is User cp.
If you select that you can edit your profile. So once you select the User cp it takes you to another screen. There you would select Edit Profile.
Once you select Edit Profile it takes you to another screen. At that screen if you look under the header titled Optional Information you will see Signature: if you look to the right of that there will be an empty gray box. There you can type in what ever you want.
You can list things about your truck etc. You can also put the path/directory to a photo you have from F150online. For now try playing around with it and if you need some more assistance on how to do pictures go here: https://www.f150online.com/forums/mi...&action=bbcode
When you are just testing out your signature and/or pictures there is a forum dedicated to that and is titled Testing 1-2-3 it is like 5 forums under General Discussion. That is where you should do all your testing because after time they delete those post to free up space…
Hope that helps if not ask…
