Attn://beastie
Old Oct 1, 2002 | 11:07 AM
SPROCKET_X's Avatar
Attn://beastie
I was looking at your homemade intake and was wondering where ya put the MAF sensor?
Old Oct 1, 2002 | 04:46 PM
beastie's Avatar
It is there. It is right before the filter. There is a MAF to filter adapter made out of 1/8" steel, and a 3" Pipe. I drilled 4 holes in it, bolted it to the MAF, then slid the filter over the 3" pipe.
The dots are where the holes were drilled
You can see the MAF,and the corners of the adapter.
If you need any more help, just ask
Old Oct 1, 2002 | 04:53 PM
SPROCKET_X's Avatar
well I already have an FIPK...but they gave me a bracket that makes the sensor sitting about 2 inches outside of the filter and it's causing it to read a little warmer, so I was think of perhaps putting a hole in my adapter and placing the MAF sensor so it's back into the filter.
So is this what you did with the sensor....I can't realy tell where it is in the pic.
Old Oct 1, 2002 | 04:58 PM
beastie's Avatar
The hole in the adapter matches the MAF hole perfectly. So it is straight in straight out. I dont really understand what you are saying. i hope this helps.
Old Oct 1, 2002 | 05:10 PM
SPROCKET_X's Avatar
I don't have a good pic of mine but here's one off of a guy with the exact same set-up as me.
See how the sensor is off to the right....I was thnking of just drilling a hole in the adapter and placing the sensor in there instead of leaving it out like this because it's reading a little warmer and it's exposed to the elements so I have to clean it often.
Old Oct 1, 2002 | 05:49 PM
beastie's Avatar
I guess that would work.
