Pinging - Any relation to PCV?
Old Jul 24, 2002 | 10:56 AM
92Pony's Avatar
Question Pinging - Any relation to PCV?
I am still constantly nosing around under the hood (and under the truck itself! ) of my '90 F150 whenever I get the time, in order to get more familiar with it. (I've put about 700 mi on it since I got it)
I had been getting a putrid, burnt-oil smell when I came to a stop, but I think I found the source - the PCV valve was sitting on top of the VC - just laying there. Well, I popped it back in (it rattled, so it's good, right?), and the smell seems to have been eliminated.
I drove the truck the next day(yesterday) (5.0, 146k mi) and noticed a low RPM part throttle ping in OD - especially if going up a grade. I've searched the forum for "ping" this morning, but haven't gotten to check on the timing, and the #7&8 plug wire phenomenon yet. Would putting the PCV valve back into place have anything to do with the ping? I wouldn't think so...
Wade
Old Jul 24, 2002 | 11:01 AM
SPROCKET_X's Avatar
I don't know much about that engine or pinging but I do know that the PCV valve is supposed to rattle...maybe the hose coming from the PCV is clogged so that might be why the previous owner took out the pcv?
Old Jul 24, 2002 | 11:05 AM
92Pony's Avatar
Yeah, I also did some searching about PCV stuff yesterday, and found out that I need to check that hose. Too bad it looks like you either have to pull the freakin' motor, or stand on top of it to get to anything back there! - LOL!
My understanding is that the truck had to have some engine work done (not real clear on exactly what was done) before I got it - could also be that the PCV was accidentally left out....
Thanks Sprocket
Wade
Old Jul 24, 2002 | 12:26 PM
SPROCKET_X's Avatar
A tune-up wouldn't hurt also...new plugs, wires ect...
Good Luck
Justin
Old Jul 26, 2002 | 12:09 AM
KYFordFreak's Avatar
The PCV rattling is a good sign at least you know it's not clogged up but just because it does rattle doesn't make it a good part. On some PCV's the spring and the onsides can wear out over time. My suggestion is just replace it since you can pick one up for under $3, under 6 bucks is you want OE from the dealer.
I had three Purolator PCV valves that would rattle excessively replaced it with a Motorcraft and it stopped. Go figure, my truck likes the expensive parts.
Old Jul 27, 2002 | 01:41 AM
PKRWUD's Avatar
EXACTLY!!!
The moron that first wrote in repair books that a PCV valve that rattles is good should be shot. That advice has become known world-wide, and it's wrong.
Take care,
~Chris
Old Jul 27, 2002 | 01:48 AM
SPROCKET_X's Avatar
My F150 Holy Repair Bible LIES?!?!
NO!!!!! grr chiltons manual is now in the wood stack for winter time!
Old Jul 27, 2002 | 01:53 AM
PKRWUD's Avatar
LOL. It's still good for some things, just don't rely on it.
Take care,
~Chris
