Truck won't warm up when its 90 degrees outside!
Old Jul 3, 2002 | 02:39 PM
supersoic491's Avatar
Ive got an 89 F-150 with a 351 in it. When it was cold out side my truck wouldn't warm up at all. So I replaced the thermostat and it would warm up to just past the C on the temp guage, but not into the "normal" area. Today I drove it when it was about 85 degrees outside and it did the same thing. When I got done driving it I let it run and stuck a candy thermometer in to the top of the radiator and it read 150 degrees. Please help this has got me stumped!
Old Jul 3, 2002 | 02:48 PM
SPROCKET_X's Avatar
hmm, maybe your gauge cluster went bad.
Old Jul 3, 2002 | 03:28 PM
Ya thats what I thought too, but the candy thermometer in the radiator read 150 degrees.
Old Jul 5, 2002 | 07:43 AM
fourhorseman's Avatar
There are different types of thermometer that you can put in the engine! I changed mine after having the same problem. I think I had a 190F in it, but went to a higher performance thermometer at 180F to keep the engine slightly cooler. Is it possible you bought a lower temp thermometer?
Old Jul 5, 2002 | 03:02 PM
Nope I checked that too. It's 195 I think. Im fairly good mechanicly and Im totally stumped.
Old Jul 5, 2002 | 04:41 PM
SPROCKET_X's Avatar
maybe it's a bad t-stat...could be stuck in the open position.
Old Jul 5, 2002 | 05:42 PM
PKRWUD's Avatar
I't's gotta be.
Leave the thermometer in the top of the radiator while the truck is running. The t-stat will start to open after 10 minutes or so, and the temp will rise suddenly. If this doesn't happen, the tstat is open. Look for flow in the radiator, too.
Take care,
-Chris
