my trucks in bad shape
ok, guys. i went wheeling maybe a month ago. it was a pretty bad showing. i got really stuck and my trucks damn near dead.
basically i need,
water pump
t-stat
new power steering pump and pulley
valve cover gaskets
seal on rear axle
exhaust
and i am sure stuff i am missing. my truck was running rough so i think i need a IAC too.
all this and i have a valve tap and a low end knock. engine needs a rebuild bad. 160,000 hard miles on it.
so, i was once parting a bronco for my truck and now i just put in a lower bjoint and a couple of u joints and the bronco is running fine. the 89 is really hurting tho. i just don't know what to do with it. haven't decided if i am gonna keep it or fix it to wheel it again.
curt
basically i need,
water pump
t-stat
valve cover gaskets
seal on rear axle
exhaust
curt
forgot to say, the starter selenoid blue to when my starter was screwed. it blue when i was hooking the starter back up after having to clean it out and lube it a little. somebody started the truck just as i was tightening the lead and it blue the selenoid.
curt
curt
