broken engine mount?
Old May 13, 2002 | 01:09 AM
superedge7's Avatar
Whenever one of my back wheels goes up on a curb or for any reason is higher/lower than the other rear wheel, radiator fan rubs on it's plasic housing. So I figure that the engine is moving because of a broken engine mount? Or loose engine mount? How much does a broken engine mount cost to fix (ballpark) Or is this something that I could possibly do myself? Thanks guys for the help.
Old May 13, 2002 | 01:40 AM
SPROCKET_X's Avatar
I did mine on my 4.9L and it was prety simple. It was over a year ago so I can't remember exact price but I want to say the mounts were like $30ish.
Old May 13, 2002 | 08:35 PM
inski21's Avatar
check the cross members of the frame. Maybe one is loose or busted. good luck
Old May 14, 2002 | 10:44 AM
superedge7's Avatar
anyone else got ideas? What am I going to be looking for when under the truck, can you give me ideas?
Old May 14, 2002 | 12:33 PM
SPROCKET_X's Avatar
get a jack with a piece of wood on it or something that would act as a coushin(so?) and jack up the engine and see if it does go up, if it does then see where it lifts up at and that should solve your problem.
Old May 14, 2002 | 01:47 PM
superedge7's Avatar
good thinking, I should have thought of that
