Simple ignition kill switch?
Cant' believe my local auto shops don't carry a simple ignition kill switch. Any idea where I can get one?
I've got a (Haynes) manual - not sure if I can figure out which wires to put a toggle switch on though.
Really don't want to have a full battery disconnect switch - just an ignition one.
Originally posted by Macgyver
Red/lt. Green wire in the ignition harness
do you have a automatic or a manual i hooked one up for my buddy and i went through the clutch saftey switch if you have a automatic try hooking on to a fuel pump circuit or pcm or somthing in that area
Your best bet, IMO, is to splice a switch inline between the inertia switch and the fuel pump relay. This won't effect the ignition, but it will prevent the fuel pump(s) from being used. The switch should be to the left of the brake pedal, on the inside firewall. There will be two wires coming from it. You can splice the switch into either wire, it doesn't matter. Pick the one that looks like it's routing will make the switch placement ideal for you.
Take care,
-Chris
Take care,
-Chris
It's an auto. On my manual tranny Toyota I put one in the clutch safety switch line.
A question about putting a switch in line with the fuel pump relay - if I forget to turn the switch on, and run it out of gas, how much of a pain in the *** is it to get the fuel injection to start working again?
It won't start with the switch off. Still, it's no big deal. You turn the switch on, then turn the key on for 2 seconds, then off, then on for 2 seconds, then off. Do this 5 or 6 times, and then try to start it. It should start right up.
Take care,
-Chris
Take care,
-Chris
