Mpg
Old Mar 23, 2002 | 12:24 PM
Macgyver's Avatar
Mpg
woooo hoooo i'm back to 15.69 mpg . had to drive 2 hours yesterday at 5:30 am to go test for LPG cert. then drive 2 hours back to work . just finished running that tank out and checked the mileage :-)
Old Mar 23, 2002 | 12:37 PM
Raddred01's Avatar
back to 15.69 mpg ?
So... Macgyver,
What you driving anyways?
Old Mar 23, 2002 | 01:05 PM
PKRWUD's Avatar
EXCELLENT!!!
BTW, good luck w/ your cert results!
Take care,
-Chris
Old Mar 23, 2002 | 01:58 PM
inski21's Avatar
Thumbs up
Good. I think I'm up to 13 or so now...after 3 months of listening to my ping, I've finally eliminated it. yeaaaah. A whole new monster now. I'm using OD again too.
Old Mar 23, 2002 | 02:11 PM
fivept0's Avatar
inski,
How did you eliminate the ping? (are you talking detonation?) I have a nagging ping as well, and the truck is such a dog, especially in overdrive and part throttle situations. And my mpg sucks too.
thanks alot,
scott
Old Mar 23, 2002 | 02:49 PM
inski21's Avatar
wed I was able to check timing that was acceptable at 8 btdc-I'll bump it once I have time again.
Made sure 7&8 wires weren't running parrallel at any point in their paths. Seperated with zip ties where necessary.
Did a Wynn's 3 part Fuel System Clean... to rid cumbustion chamber and intake of carbon build up.
To be honost I think it was the 7+8 wires all along!
I'll let yoy know how far I can go w/ timing. Now that ping is gone I bet at least 12 maybe even 14. It feels that good.
Old Mar 23, 2002 | 02:56 PM
fivept0's Avatar
Thanks,
I'll try seperating those wires today. I'll let you know what happens...
scott
Old Mar 23, 2002 | 02:57 PM
PKRWUD's Avatar
Old Mar 23, 2002 | 10:48 PM
Macgyver's Avatar
won't know if i passed or not for a week and a half . i drive a 1990 F150 XLT lariat 5.0 L w/ AOD and 3.55's with 235/75r15 cooper lifeliner II's (28 inches tall )
Old Mar 25, 2002 | 03:28 PM
colorado's Avatar
Question for McGyver
..I just picked up a 1990 F350 ( with the 5.8 litre )...I noticed that you had gotten your MPG to an almost acceptable level....
What have you done that was the most effective, yet not too $$$
Just curious, cuase I'm pulling about 10 right now if I'm lucky....
Truck runs great, but it's a pig.
Old Mar 25, 2002 | 04:13 PM
Donate54's Avatar
colorado,
remember, an f350 is a seriously heavy truck, so its gonna be tough getting good gas mileage on a heavy truck like that with a 351.
Old Mar 25, 2002 | 04:37 PM
colorado's Avatar
I realize that it's going to be bad...but I'm hoping to get away from " horrible "
Old Mar 25, 2002 | 05:55 PM
inski21's Avatar
The usual tune-up stuff. Plugs, wires, rotor button, cap, fuel filter, K&N air filter. Check timing and adjust as needed, check alignment and air pressures. 10 mpg in a 350 aint bad.
is your rig 4wd?
Old Mar 25, 2002 | 06:48 PM
Macgyver's Avatar
as inski said . but i also just got done reading the ecm and replacing about $600 worth of sensors and doing a tune up /oil change etc.. it still wasn't back to that mpg (was closer to 13.5 ) til this last tank . when it was really bad before i did all the work i was down to 11.5 .
Old Mar 26, 2002 | 10:41 AM
colorado's Avatar
bad mpg...
Yep...and did I mention crew cab with slightly oversize tires...
Do the K&N's make a big diff?
and how about retarding the timing a bit?..I've heard that if I get it BTDC ( a couple of degrees ) it can help as well.
