351 throttle body...
Old Feb 23, 2002 | 01:39 AM
fivept0's Avatar
Question 351 throttle body...
Does anyone know if the 351 uses the same size throttle body as a 302? (non lightning) If its bigger, do you know if it can be adapted to a 302? They look like they would work? I know there's tons of these in the junkyard and if the size is bigger I may try putting one on my truck.
scott
Old Feb 23, 2002 | 01:41 AM
Macgyver's Avatar
yes it will work . during my truck work i took the one of our shop truck and put on mine . it was a 5.8 l. i dont think it is any larger diameter id then yours tho .
Old Feb 24, 2002 | 10:52 AM
Macgyver's Avatar
one issue you need to keep in mind that even if you put a larger TB on it is still restricted by the stock size of the plenium behind it . this will need ported and polished to the size of the TB or larger .
Old Feb 24, 2002 | 06:15 PM
Macgyver's Avatar
here is some info i found . will bolt to stock TB with no mods to plenum. price is $287.00 + S&H
Ford: 1987-96 5.0L-5.8L F150-350, twin 61 mm, 50-state legal, cast aluminum, performance throttle body
This Edelbrock high-performance throttle body is part of a winning combination for today's late model 5.0L-5.8L truck enthusiast. This twin 61 mm throttle body is ideal for stock manifolds and produces approximately 15 percent more air flow than the production throttle body. It's also 50-state street legal for all 1987-96 5.0L-5.8L F150-350 trucks. Gaskets are included.
Old Feb 24, 2002 | 06:41 PM
fivept0's Avatar
Thanks Ray,
I've seen the edelbrock throttle body, but I figured If the 351 TB was bigger than the 302 It would be a cheap upgrade. I see in your sig that you are planning to get an edelbrock...let us know how you like it.
Anyone else using the edelbrock throttle body?
scott
Old Feb 24, 2002 | 09:07 PM
Macgyver's Avatar
probably wont be anytime soon . for that or the chip . going to try to get the pulley's tho asap . then will save up for the TB. then the chip.
Old Feb 25, 2002 | 02:25 AM
signmaster's Avatar
There is a guy over at the NLOC boards with both throttle body and intake for sale. Go to NLOC.net and check under MISC parts.
I just noticed it the other day and he didn't have any offers yet. It should be easy to spot.... I can't remember the thread title, but it caught my eye.
Old Feb 25, 2002 | 09:14 AM
drm7's Avatar
stock throttle body size
I saw where edlebrock sells a twin 56mm & twin 61mm tb for 302/351. Does anyone know the stock size for the 351w tb w/speed density? (my truck is a 94) Will a tb replacement give me more low-end torque? I'm not interested in high-end hp as I tow a boat and need the low-end tq more than the hp gains. I'm planning a K&N drop-in with a modified airbox. Also, does anyone have experience with ignition changes? Will a Jacobs or MSD give me more torque or are they better for high-end hp?
Thanks!!!
Old Feb 25, 2002 | 06:46 PM
Macgyver's Avatar
i checked my TB size today . it appears to be 53 mm . so either of the edelbrock TB's are larger . as far as the numbers go (dont know if it is high end or low end ) i believe it is about 20 hp and 15 to 25 tq. , i'd like some info on the msd ignition parts also i am thinking about that too.
Old Feb 25, 2002 | 06:52 PM
fivept0's Avatar
Thanks for measuring that for me Ray. I'll measure mine today to see if there the same size...
scott
Old Feb 25, 2002 | 11:20 PM
curt73@aol.com's Avatar
I was never a big fan of changing the ignition, i think ford is just fine. if you go wheeling and something brakes out in bum**** what do you do for parts. at least you can go to a dealership or napa or something for stock parts.
curt
Old Feb 25, 2002 | 11:34 PM
Macgyver's Avatar
curt
ignition? i think ya got the wrong thread curt
i agree tho . i plan on getting an accel coil and accel tfi . but thats as far as i'll go
Old Feb 25, 2002 | 11:44 PM
i just mentioned it because somebody mentioned it a post. might have been you ray. something about msd. curt
Old Feb 26, 2002 | 01:44 AM
signmaster's Avatar
curt
With my Jacobs I can switch to stock in about 1 minute, and 20 seconds of that is pulling the hood release and opening it up.
Old Feb 26, 2002 | 01:03 PM
2che, guess that will work.
