0-60 time
Old Feb 16, 2002 | 09:15 PM
86Fordman's Avatar
0-60 time
Does anyone know what the official 0-60mph time is for 92-96 F150,5.0 2wd trucks is?
Also, has the horsepower and torque changed at all from 86 to 96 on the 5.0 E.F.I. ?
Old Feb 16, 2002 | 10:39 PM
inski21's Avatar
ten minutes seven seconds.
There is a difference when they changed to MassAir.
It all depends where you are, whos driving, temp, humidity.
I don't know any of the factory #s or magazine test #s.
Old Feb 17, 2002 | 01:50 AM
signmaster's Avatar
If I remember correctly there were two HP bumps between 86 and 96. The '86 should be around 185. The later models were 200 to 210 depending on emissons and computer calibration code. From everything I've seen the mass air trucks are rated slightly higher, but not all trucks got mass air at the same time.
Torque stayed close through the years, the later trucks were 270 or 275 depending on what source you believe.
Keep in mind also that some of the later years had the wide ratios in the auto tranny.
