timing
timing
can someone explain to me exactly what the timing of an engine is? exactly how do you change the timing of an engine? ive always heard people say that they advance or retard the timing by x degrees, what does that do? thanks for the info, just trying to learn!
when someone says degrees they are talking about degrees of crankshaft rotation. If stock timing is 10 degrees BTDC (before top dead center) then the sparkplug fires when the crankshaft is 10 degrees before the piston is at peak travel(highest point)
generally an engine will run better with more advanced timing,but too much advance causes detonation(pinging) which is a VERY bad thing.
Advance means to make the plug fire sooner- like going from 10degrees to fourteen
Retard would be like going from 10 to 6
Timing is adjusted by loosening the distributor bolt and turning the distributor.
I hope I explained this clearly. If someone else has better wording feel free to chime in.
Originally posted by PKRWUD
Just don't confuse ignition timing with valve timing!
Take care,
-Chris
Take care,
-Chris
. thanks a lot guys!
