Need help with a connector pinout from1987 F150 Lariat 5.0l
Old May 1, 2025 | 05:48 PM
Wiredjackofalltrades's Avatar
I hope someone is able to help me with a pinout of this connector that is located under the hood on the driver's side of my 1987 F150 5.0l. The connector crumbled apart diagnosing some electrical issues in the truck and now I'm unsure of where the wires go. I do have one side of the connector that I can almost make out all of the colors of the wires but there are 1 or 2 I'm unsure of what color they are supposed to be pink maybe orange? Unfortunately the other half of the connector I have no idea which wires go where and to top it off have lost some of the pins (the connector had to be cut out since it was unusable) I took a picture of the plug along with 7 pins I do have for the side of the connector that fell apart. Some of the pins the wire broke off right where the pin was crimped onto the wire so there's no wire color for 1 or 2 of the loose pins that I taped. I taped the pins together just to hold the them in place to get a picture of the wire colors. The connector is a 12 pin connector but I belive there were 13 or 14 wires so 1 or 2 pins must've maybe had 2 wires to 1 pin? I have spent hours trying to find a pinout of this plug online with no luck.
PLEASE NOTE: The first image I uploaded below is NOT an actual photo of the connector off of my truck it is only to reference what the connector looks like. I am unsure if the wire colors are different or same as my truck but from the ones i can see it appears to be the same. The rest of the images of the connector shown below are pictures from the plug that was removed from my truck. Any help would be greatly appreciated!
This picture is NOT an actual photo of the connector off of my truck it is only to reference what the connector looks so i am unsure if the wire colors different or same as my truck. The rest of the images of the connector shown below are pictures from the plug that was removed from my truck.
