Gearing help!!!
Old Mar 3, 2025 | 05:14 PM
Moore087's Avatar
Gearing help!!!
I need some help, I have a 95 f150, 2wd with the 8.8 rear with 3.08’s from factory. Got decent gas mileage for something shaped like a brick with the stock 235 tires. I recently lifted it 2.5” and threw on some 32x11.5x15s. Now the truck will not stay in overdrive on the highway. Not sure what rpms I’m running due to not having a tachometer. I’ve recalibrated the PSOM and that helped a little and my speedometer is still 5mph off which isn’t a big concern. What gear ratio do I need to switch to or do some of yall recommend. I don’t tow anything heavy, at most 4000 lbs every so often, this is mainly my daily driver with quite a bit of interstate 70+ mph driving. Any help or guidance would be greatly appreciated!
Old Mar 3, 2025 | 10:43 PM
3.55's would put it back close to stock. However, with the lift and wider tires you may want to look at 3.73's.
