Fuel problems
Old Apr 29, 2023 | 09:19 PM
JBostic's Avatar
Fuel problems
Hello! new to the page, and new to the 8th-gen Ford's first time owning one of these body styles and a fuel-injected I6, so please excuse my ignorance lol.
I just purchased A 1987 F150 EFI 300 6. truck was running well, went to start her up today and started down the road, I was lacking power and could barely move in second gear as if the truck was only firing on 2-3 cylinders and not getting fuel, parked the truck and if you slowly ease into the accelerator it sounds and runs fine, but if you give it any gas very suddenly it almost stalls and will not kick back and sounds like only two cylinders are firing, and it's starving for fuel. After a trip to the parts store replaced the plugs, wires, fuel and air filter, checked the fuel pump and it seems to be strong and working well and very little change at all, I did notice the fuel filter was dirty, but after replacing it, it does not seem to have helped much, so I'm lost on what to do next, thanks for any advice!
Old Apr 29, 2023 | 10:12 PM
Check the fuel pressure with a gauge, 45 psi minimum at idle, should jump to 55 when you hit the gas. 55 at idle with the vacuum line off the fuel pressure regulator. Check for a clogged cat. Put some Iso-Heet and some fresh gas in the tank. Check the rotor and distributor cap.
