Trans fluid leaking it shows up around the trans mount and replaced pan and gasket but still leaks can't find it is it a seal or something else
You should check the tail shaft seal where the driveshaft goes into the trans as it could be the trouble. They sometimes crack the rubber if they set for a time. The rubber dries out from not having any oil splashed on it.
