1981 Ranger 302 Only starts in neutral
Old Apr 12, 2021 | 09:15 AM
Zmcdonald's Avatar
Question 1981 Ranger 302 Only starts in neutral
Ok so I have a 81 Ranger Lariat with a 302 V8. issue I'm having is the truck will turn over for 1-2 seconds and then sound like its binding up. But, if the truck in neutral it fire and stay running I believe the transmission is a AOD trans maybe? 3 speed auto. Any help would be appreciated. Thanks
Old Apr 12, 2021 | 09:17 AM
I would start by looking at the linkages.
Old Apr 12, 2021 | 10:26 AM
Zmcdonald's Avatar
So let me ask you this. Would this cause the engine to make a binding sound in park when trying to start the truck?
Old Apr 12, 2021 | 10:29 AM
Your transmission is a C6. I'd be looking at the neutral safety switch.
Old Apr 13, 2021 | 09:06 PM
Zmcdonald's Avatar
So the only wires to the transmission is to a NS54 safety switch but according to the wiring diagram its sole purpose is for the reverse light. Everything seems to check out on the switch. With the switch unplugged the truck still not start in park only in neutral. Is there another neutral switch somewhere like on the steering column or something? Pulled the trans dip stick not really the bright pink I was looking for also smelled kinda burnt would there possibly be something internal that failed causing all these issues?
