sometimes the fault is obvious even to me
Old Jun 29, 2020 | 03:32 PM
somemorebob's Avatar
Check out this reasonably obvious reason for a CE light from a DPFE sensor fault.
Old Jun 29, 2020 | 07:34 PM
Did you accidentally drill into it?
Old Jun 29, 2020 | 08:00 PM
No. I don't know but it appears that the tubes melted off the bottom of it and hot exhaust melted it's way through it. Might have been a inferior Kung Flu made part.
Old Jun 29, 2020 | 08:58 PM
Interesting. Looks just like someone got a dull drill bit and had at it... lol
Old Jun 29, 2020 | 09:44 PM
I wish that was it instead of maybe the sampling lines turning into a plasma cutter, lol
Old Jun 29, 2020 | 10:00 PM
You used to be able to buy metal DPFE's. Now they are all plastic. I believe the OEM on yours was in fact metal, it must have been replaced before.
Old Jun 29, 2020 | 10:17 PM
It was, and you can find the replacements from $10 TO $80, and they are all probably the same plastic crap.
Old Jun 30, 2020 | 12:14 AM
Bob, you have a 1996, right? Most Fords from 1996 to 2004 used the same DPFE, most engines. Hit the junkyards and see if you can find a metal one.
Old Jun 30, 2020 | 09:15 AM
Good thought, thanks.
