I need help please... I have a 1988 F150 standard truck. The motor is a 300 six cylinder 4.9. It does not have air conditioning, no power windows or locks. It is a basic truck.
This fuel pumps in both tanks are not working.
[list]All fuses under dash are working.
I replaced both relays under the hood with new ones.
I replaced the ignition coil and it is getting a good spark.
I removed all the connections on the solenoid and sanded each connection to remove any rust.
I confirmed the solenoid was working properly with my test meter.
I replaced the tank selection toggle switch on my dash with a new one.
Both fuel tanks are full of gas.
I used a rubber hammer to hit each tank hoping it would caused the fuel pumps to come on and did not work.
When I turn the key to the on position I can hear the high pressure pump cycle on for about 2 seconds but i cannot hear the pumps in either tank come on.
I can spray starting fluid into the throttle body and the truck starts with ease and runs very smooth until the starting fluid is completely used.
The past two mornings I went out to try to start it and when I turned the key to the on position I could hear the fuel pump in the rear tank come on. Yesterday morning the truck ran smooth for about 4 minutes and then shut down and would not start back up. This morning I could hear the fuel pump in the rear tank and started the truck and it ran pretty rough for less than 1 minute and would not start back up.
The fuel gauge shows empty when the front / rear toggle switch is on the front tank. When it's on the rear tank the fuel gauge shows full.
I tried to pull codes from the computer by jumping the EEC and the check engine light stayed on and would not work for me.
Question: If the tank selector valve under the truck was clogged.. would that prevent both tank pumps to come on?
I attached a picture of two connectors... Could anyone tell me what they are please?
