1991 F150 4x4 drivetrain problem.
Old Dec 14, 2018 | 07:35 PM
David Shepard's Avatar
Hi. I am having an issue with my truck. It has an E4OD transmission and the BW13-56 transfer case.
After starting the truck the column gear selector will move through the range, but none of the gears actually engage. I can roll the truck while selector in park. if I do roll the truck about 6 ft,,sometimes it will go into gear and drive fine until I change gears. Any ideas? Ps. fluids full.Thanks
Old Dec 14, 2018 | 07:58 PM
Check your shift linkage from the lever to the transmission and the MLPS (neutral safety switch, it also transmits the lever position to the PCM).
Old Dec 15, 2018 | 08:00 AM
I thought Neutral safety switch involved being able to start engine while not in park or neutral. Truck starts fine, moving gear selector has no effect
Old Dec 15, 2018 | 10:29 AM
The "neutral safety switch" is a MLPS, it also transmits the lever position to the PCM for transmission electronic control.
