High mileage mantainance
Old Jul 31, 2018 | 10:44 PM
Roadie's Avatar
Yep, couldn't have been the local Ford dealer! 6 or 7 years ago, my son's 2000 Ford Mustang V6 developed a miss on #3 cylinder. I was working away from home so I told him to take it to the dealer. They charged over $900 for new spark plugs and one injector!
Old Aug 1, 2018 | 11:11 AM
Hooligan866's Avatar
Definitely not the stealership. Although it will be going there as soon as I get it back for the clock spring recall. I’m sure they’ll tell me it needs $1000 worth of other stuff
Old Aug 2, 2018 | 12:17 PM
The old front U Joint for the rear driveshaft. I’m lucky I didn’t pole vault the truck on the way back from FL 😬
Old Aug 2, 2018 | 12:43 PM
Yes you are! I did the pole vault one time in a 1954 Ford Coupe running about 70 mph. Ended up in the ditch.
Old Aug 2, 2018 | 01:14 PM
ouch!! I’m no mechanic , but the thought crossed my mind when I was driving “what if the drive shaft falls out in the front” Had a few mini freak outs every time I thought of it. But, alas, I was spared and after all of this work, she should run like a top with few worries
Old Aug 2, 2018 | 07:13 PM
Roadie's Avatar
Maybe you should buy some lottery tickets! You were lucky that u-joint didn't fail and at least leave you on the road.
Old Aug 2, 2018 | 07:43 PM
prayer glue was the only thing holding it together. 😂
Old Aug 9, 2018 | 01:22 PM
Still in the shop. No leveling kit installed, I guess it threw everything off. Needing upper and lower ball joints, so there’s another $300. I hope I’m not in over my head 🤔. That should be the last thing needed, for now.
So far- new clutch, new universals, upper and lower radiator hoses, new tranny mounts , new fuel filter, radiator flush, rear diff fluid and gasket and ball joints getting done now- $1400 total. Decent price for all of the work, I guess
Old Aug 9, 2018 | 05:56 PM
Roadie's Avatar
Decent price I'd say. Vehicles cost bucks used or new. Hopefully used cost less.
Old Aug 9, 2018 | 06:56 PM
He said the engine is in great shape. With all of these repairs, hopefully she’ll stay on the road a few more years
Old Aug 9, 2018 | 10:35 PM
Roadie's Avatar
Repair costs so far are miniscule compared to buying a new truck.
Old Aug 10, 2018 | 02:20 AM
Agreed.
Old Aug 10, 2018 | 07:52 AM
This is why I like zerked u-joints... I like to keep an eye on them.
You got lucky!!
Old Aug 15, 2018 | 11:28 AM
Hubs were shot too, so I’m replacing them with Warn stainless hub lockers. I assume Warn is one of the better ones. Correct?
Old Aug 15, 2018 | 12:27 PM
Yes, Warn makes great aftermarket hubs.
Your progress reminds me of a buddy and I who are working a 1997 Van hool. We work on a little bit, and find a few more things to replace.
