Crank no start
Old Jun 19, 2018 | 09:11 PM
1986F159 351w's Avatar
Exclamation Crank no start
Hi this is my fist post. I have a 1986 f150 351w carb. I have just put in a new intake manifold and valve covers in it. After taking out smog pump and putting new radiator in it I have a crank no start. It is getting gas. I am thinking it is spark or I did not install the distributor in same spot? I did put new plugs and wires. It was running fine before this was just leaking oil. Any help woud be great thank you.
Old Jun 19, 2018 | 09:54 PM
Roadie's Avatar
Double check what you did. As I remember the firing order is different for the 351 compared to a 302.
I had an 86 302 F150 for a while and it had a weak ignition module. I think the ignition modules fail because they are right behing the radiator and get very hot.
Old Jun 19, 2018 | 11:40 PM
Have you TESTED for spark?
Firing order and distributor position, note where the cap clips are:
Old Jun 20, 2018 | 11:13 PM
Thank you for the help. I got it running. It is smoking out of driver side valve cover. Any ideas?
