Pcm reset for 96 f150 5.0 4x4
Having a couple issues. Motor is 5.0 trans is e40d.
Trans once waned up getting torque converter trouble code, it's shifting late and the speedo is not accurate. Od light flashing. Shifts 1,2, late into 3 and even later into 4 once in 4 it tries to. Keep shifting back into 3.then back to fourth after a longer than normal period. Can resetting pcm possibly restore and fix the problem? Or is. This a good start Also how do I do that?
