Spout Connect Does Not Advance Timing
Old Mar 23, 2013 | 05:44 PM
1991FTRUCK's Avatar
I have a 1991 F150 XLT with automatic transmission and 5.0 engine. I recently had a no start condition and thought the timing had jumped. I replaced the timing chain and sprockets (timing did not jump).
I replaced the ICM on the side ove the distributor and now the truck starts and seems to have plenty of power. I disconnected the spout and set the timing to 10 before TDC. When I reconnect the spout it only advances about 2 degrees. Before the no start I retimed and when I reconnected the spout it would advance around 19 degrees.
When I drive the truck under load there is a rattleing nois (like a paint can). I am not sure if this is because the timing is not advancing. I also have white smoke from the exhaust but am not losing coolant and do not have coolant in my oil.
I ran KOER test and have code 44 and code 13. Is this a vaccume problem?
Please help.
Sorry for the long post.
Thanks.
Old Mar 23, 2013 | 11:50 PM
If you are getting a rattling noise, that's spark knock which means it's too far advanced or running excessively lean.
Code 44 is a problem with the Thermactor system (air injection - smog pump). Code 13 is an idle issue.
