95 f150 fuel dual tanks
Old Mar 21, 2013 | 10:15 PM
rigid1's Avatar
Background
I think front pump went out a couple years ago so I have been using the rear only . Drove home and parked . Next day truck turns over but I don't hear pump prime . I assumed both pumps are now out . Rear tank leaked anyway so Bed is off , rear tank out and both pumps are unplugged .
Before i spend money on pumps I am trying to be sure that is the problem . Here is as far as I have gotten .
with relay unplugged in the box under the hood and looking at the location from the fender where the relay plugs in
12 o;clock power w key on no power with it off
3 o clock power on and off
6 oclock no power either way
9 oclock same
selector switch harness on dash and switch un hooked . very dim power to yellow wire with white stripe with under hood relay in place and unplugged . No other terminals show power in the switch harness .
No power at the inertia switch harness .
Any ideas on what my next steps should be ?
Thank you
Old Mar 24, 2013 | 10:00 AM
lammon's Avatar
http://easyautodiagnostics.com/ford/...ad_relay_1.php
Try this site it is pretty good for testing the fuel system
Old Mar 30, 2013 | 11:25 AM
rigid1's Avatar
Thank you for the information . Mine is different than that and it looks like the chart on that link only goes to 92' . Do you know of any other links I can try ?
Thank you again
