4.9 injectors ?
Old Mar 16, 2013 | 07:03 PM
chuckd's Avatar
4.9 injectors ?
hey guys
i picked up a clean,very clean 1988 f150 4.9 EFI motor,stick shift,4wd
truck ran great for a few days,then started running poorly,stalling,etc
oil level is high,smelled like fuel ?
checked fuel pressure,ok
pulled plugs,#2,4 and 6 were black fouled
unplugged ignition module,cranked the motor with the plugs out - fuel mist was noted at those cylinders ?
think injectors are stuck/leaking down ?
Old Mar 16, 2013 | 09:45 PM
That's the first thing I'd check. Other possibilities are bad plug wires and a worn out/cracked distributor cap.
