Theres a guy that has a 89 F150 5.0L 4sp in great shape. But it dies when he goes on the highway at a higher rate RPM speed. It does fine in town, dosent die. But like on the highway it dies. Let it sit for an hour or two it starts up just fine.
Need Help!!!
Need Help!!!
It's most likely the pickup coil in the distributor. I would try the coil and the ignition module first as they are easier to replace. If it come to replacing the pickup coil in the distributor, get a new distributor from Oreillys. Rebuilt distributors are junk.
You would want to check to make sure it's ignition you are losing when it quits. I'm quite confident you will find you are losing ignition.
sounds almost like a heat issue somewhere....
Where would it be loosing heat from?
So Masseyman, try replacing the top of the distributor and bug etc.
Quote:
The stator or PIP or ignition pickup it goes by several different names. You can go buy a new one of these and install it in your present distributor. One problem here though, it requires the distributor be removed and disassembled. A little tricky but doable if you have the proper tools. I would personally go to Oreillys and buy a NEW reproduction distributor. They run around one hundred dollars I think. If you don't have an Oreillys near you, you can order online. Originally Posted by yorkwford93
It could also be the coil, or possibly but not very likely, the ignition module on the side of the distributor. I would be inclined to try the coil first. Kind of a bummer to solve when it quits on the highway and the guy has to wait an hour or two for it to restart. Forget about trying to test these parts because if they are working to run the truck, they will fire when tested.
A whole NEW not remanufactured distributor down here is 80.99, Ill probly buy that
