Tranny oil overfill/dipstick questions
Old Feb 22, 2013 | 08:47 PM
Twkenny's Avatar
Had a shop replace my AOD wth another AOD. Lot of fluid leaking under the truck. Checked trans oil level this evening and it appears to be very overfilled. I know they had an issue with the dipstick tube sealing but how can I be sure the correct dipstick and tube are installed? Assuming the correct parts were installed, is a pump the best way to get the excess oil out? Fluid looks and smells brand new still. It's just aking a mess in the driveway and I don't want to risk blowing seals or foaming the fluid.
Thanks for the input.
Old Feb 26, 2013 | 06:32 PM
adrianspeeder's Avatar
If I'm not gonna drop the pan and change the filter, but just want to change the fluid, I undo both cooler lines up front from the radiator, put some rubber hose to 'em into a bucket, then idle the truck and let the trans do the work.
I suppose there is no way to know for sure on the dipstick accuracy unless you completely drain the case/pan/valve body/TC and refill from the start.
Adrianspeeder
