The carb
If you can find a good old time mechanic who still works on carburetors, I would have him install a kit in your present carb. Carb kits are still readily available through the automotive parts places. This is assuming the body of your carb is not damaged.
If you have an AOD transmission you'll probably have to stay with the 2100. Many aftermarket carbs aren't compatable with the AOD's cable setup. The 2100s are very easy to rebuild. If you rebuild buy a new float (not in the rebuild kit) and check the throttle shaft to body excessive clearance and binding.
Regards
rikard
Regards
rikard
