A/C stops blowing when accelerating
My A/C stops blowing through the dash vents every time I accelerate. Works fine once I let off the gas. I'm pretty sure it has something to do with the vacuum system but don't know just where to look. I have seen many threads with suggestions about the "door" being loose but this is not my case. I'm pretty sure there is a loss of vacuum to the dash control that operates the "doors". Can anyone tell me where to look? Someone has suggested something about a valve somewhere that may be bad that is supposed to keep vacuum going to the controls even during acceleration?
Thanks 1997 Lariat 4.6
Thank you so much. That was exactly the problem. Had to cut the line at the "fitting" then trim the "fitting" enough to get the line back up into the fitting and a little tape to keep things tight. Works like a champ. I don't think the A/C has blown that hard out of the dash vents since I have had it. LOL
This is a 7 year old thread, he may not be around any more. You could post a thread in the HVAC forum.
