351 w gurus needed engine rebuild project!!
Old Jan 28, 2012 | 06:56 PM
High Output's Avatar
Well my timing cover is leaking antifreeze so I just might pull the motor & kind of rebuild it, I found some like new gt-40 heads off a 351 boat motor like new $350 bucks , also I see on ebay there are some off a 98 302 mercury like the explorer with f 77e casting number same $$$ but then would need rebuilt, what do I look for in the head ? I see they have aftermarket ones alluminum but I dont want to spend that much money .. Thanks for help..
Old Jan 28, 2012 | 09:19 PM
losthillbilly73's Avatar
gt40 all the way and if u can find the matching intake and throttle body it will make them that much better. what year is the truck?
if it isnt maf id convert it
if ur doin a rebuil id go with a mild cam and or 30 over
Old Jan 29, 2012 | 08:52 AM
its a 1994 , u say gt40 I know that but there are diff ones does it matter, they have 4bar etc it must mean the cc size.. I only have 115000 miles motor runs great, no need to bore other than wanting more power, but to do a cheap rebuild is a diff story..
Old Jan 29, 2012 | 10:13 AM
i was figuring when u said rebuild it had alot of miles and u were going to dip the block
if i was u id just clean and inspect everything replace all ur gaskets and put a new oil pump lifters and timing chain in wile u got it apart then what ever heads ect u deside on
i dont remember the difrances in the heads some one else may be able to tell u
Old Jan 29, 2012 | 11:35 AM
Well said but I guess ill know more if I go that far, u never know what it looks like inside until its apart, the oil pan & pump was replaced cause it rusted out, original owner, but I would put the best pump in it anyway acc to what I end up doing to it...
Old Jan 29, 2012 | 11:58 AM
true
