T19 to BW1356 Intermediate Case
Old Dec 24, 2011 | 07:14 AM
adrianspeeder's Avatar
Originally Posted by russo2
87 was the last year for the 4 speed in any trucks as far as I know.
The idi and bigger gassers got the zf and the 300 and 302 got the m5
No. The T-19 was available even in Bronco's and F-150s until '93. But for 88 and '89 I've only found it behind the diesels.
Simply need the door jam sticker trans code. VIN not needed.
Adrianspeeder
Old Dec 24, 2011 | 06:50 PM
5Rangers's Avatar
Sweet.
Just because I'm curious now, what is your trans code on the door tag? And what are the last couple numbers of your vin?
Like mine is 0074 or something like that since it was the 74's off the line.
I'm just thinking maybe it was a very early "88" build and got a t19 over an m5 for whatever reason.
The door tag unfortunately is loooooong gone. I'll get you a few numbers from the vin... I tend to agree with you because I think I read somewhere in my travels/research that it was a very early 88...
Old Dec 24, 2011 | 08:27 PM
StrangeRanger's Avatar
How to tell a T-18 from a T-19
Scroll down:
http://www.motivegear.com/tech_info/...nny_guide.html
Old Dec 24, 2011 | 09:00 PM
5Rangers's Avatar
Thanks for the link strange, been there before and its informative for id'ing... Anyway, like I said... T19... I guess I shoulda took a pic while it was all clean and painted and sittin on then workbench.... Anyway,, its up in the tunnel now. I could still take a pic though if someone wants.....
Old Dec 25, 2011 | 01:56 AM
russo2's Avatar
Do it.
I wanna see for swap purposes since your truck is quite similar to mine.
Old Dec 25, 2011 | 11:31 AM
5Rangers's Avatar
Here ya go Russo,, I still have to put the finishing touches on the install after the clutch/seal change. Let me know if you need any other views...Merry Christmas!!!
Old Dec 25, 2011 | 03:40 PM
russo2's Avatar
Sigh. I'm so very tempted to say screw this junky m5 and get me a t19
But the jy one could be just as bad as my m5.
Wonder if they use the same clutch?
Old Dec 25, 2011 | 06:23 PM
5Rangers's Avatar
Not sure, something makes me think not because when I ordered my clutch I had to specify a 4spd..
Old Dec 25, 2011 | 08:32 PM
russo2's Avatar
Gay. Guess I'm stayin with a 5 speed. There is just some so bad *** about the old 4 speed.
My clutch has just over 10k miles on it now..
Old Dec 26, 2011 | 05:13 AM
5Rangers's Avatar
BTW,, I would like anyones advice on this slave cyl. Something doesn't seem right about it, all that holds it here is the pressure againt the clutch fork. Seems there should be some kind of retainer?
Plus it will get a dollup of grease at the cup....
Old Dec 26, 2011 | 06:37 AM
Look at the casting number. 13-01...
That's a T-18
Old Dec 26, 2011 | 09:58 AM
5Rangers's Avatar
You're right Stranger and Adrianspeeder, I stand corrected, thanks for helping me to clear this up. Guess I couldn't see the forest for the trees. I saw the motive page and the Novak page and the stamped number on the case but didn't read good and put the pieces together.
I also have the ID tag on which the number "E8T3-ASA" From the Novak Adapter site: E= 80 and 8= 8th year, so 88 production
If you can locate the production ID tag on your Ford T18 top cover, you will find a lettering code akin to “D7T3...”. This may help identify the year of transmission, as Ford uses the first letter to designate the decade (C=’60s, D=’70s, etc.) and the year is called out by the second digit.
Also:
The Ford and some Jeep T18s enjoys a very low compound gear at 6.32:1 and as such it is a popular choice for those wanting a very low crawling gear.
This is even better news.
http://www.novak-adapt.com/knowledge/t18_t19.htm
Any ideas about the slave cylinder and mount?
Old Dec 26, 2011 | 03:47 PM
russo2's Avatar
So you got a t18 in an 88. Lucky.
I got nothin on that slave mount sorry.
Old Dec 27, 2011 | 10:22 PM
No worries, I've just been researching these trucks quite a while.
Although found a new oddball truck yesterday my friend bought that is an '88 F-250 with a factory 302 and AOD. Never saw one before, just M5OD's behind the 302 in the 250 flavor.
Slave looks good to me, but all my 4 speed rigs are mechanical clutches. Ain't like it'll fall out unless you lose hydraulic pressure. Then yer screwed anyway.
Old Dec 31, 2011 | 02:18 PM
5Rangers's Avatar
Yessir!!! You are correct. Anyway, I went to the junkyard yesterday and the guy gave it to me. Its a C shaped half inch thick semi-flexible plastic piece that clips onto the slave.
