Oil leak issues...
Oil leak issues...
I have a 1987 f150 4X4 I6. I am getting an oil leak somewhere down the driver side of the engine. Had the valve cover gasket replaced because it was leaking too and that got rid of most of the leak but there is still some oil coming from somewhere. What kind of drain plugs are on the driver side of the engine that I could check? Any replies would be greatly appreciated.
Valve cover or the oil pressure switch near the rear of the block. My son's 4.9L had a leak in both places before he traded it a few years ago.
The fix:
1. Replace valve cover gasket, neoprene/rubber if possible.
2. Replace the oil press switch, use teflon tape on the threads.
The fix:
