no power to fuel pumps
Old May 28, 2011 | 03:40 PM
trex1928's Avatar
sorry guys, this was my first time on this site. i am going to try your suggestions tomorrow. thanks, i realy appreciate it.
Old Jun 2, 2011 | 06:55 PM
trex1928's Avatar
Exclamation 1998 ford f150 no fuel to fuel pumps(PLEASE HELP)
Ok, I grounded the fuel pump relay to the return signal ground on the dlc. pumps running when grounded, disconnected the fuel line from outlet on filter and gas spewed everywhere. still no fuel to throttle body. pumps will not run unless bypassed on the dlc. truck has a internal voltage regulator on the alternator, had it checked and is fine. new ignition control module. i'm lost and need a lot of help. Pleas HELP.
Old Jun 4, 2011 | 12:21 AM
Steve83's Avatar
Anytime would be a good time to get a fuel pressure gauge.
Good. Fuel should never go to the TB in a Ford truck. They use MFI exclusively.
Old Jun 4, 2011 | 11:14 PM
trex1928's Avatar
I will get one. I have a question though and only because I dont know the answer. How does the fuel pressure play a role in the fuel pumps not having any power unless bypassed at the dlc? Althogh I havent checked the power at the pumps with a meter, i do know that they are not running unless bypassed at the dlc.
Old Jun 5, 2011 | 02:07 PM
Steve83's Avatar
Re-read post #14.
Old Jul 11, 2011 | 04:25 PM
trex1928's Avatar
fuel pressure fine when dlc jumped. would the disributor have anything to do with it? i replaced the ignition contril module on the distributor. all help is greatly appreciated.
Old Jul 11, 2011 | 05:28 PM
Steve83's Avatar
Yes, the PIP output is what tells the EEC to turn on the FP relay. If the dist is unplugged, the signal will never make it to the EEC.
Old Jul 11, 2011 | 07:13 PM
trex1928's Avatar
PIP?? where would the distributor be unplugged? the only wires I saw was to the module on the disributor that I replaced. the inline high pressure pump shows both electric legs grounded. When the dlc is jumped and the pumps are on the fuel injectors are not opening. I'm lost
Old Jul 11, 2011 | 11:33 PM
Steve83's Avatar
This is like pulling teeth! I'm through until you go back through this whole thread and FOLLOW THE ADVICE YOU ASKED FOR. ALL OF IT.
Old Jul 11, 2011 | 11:50 PM
trex1928's Avatar
Sorry for the frustration but just a little confused. The pip is a pick up sensor in the distributor, correct? how do i test it without replacing the distributor? PLEASE PLEASE help. This is just greek to me in a lot of cases. The mechanical functions are no problem to me but the electrical is a problem.
Old Jul 16, 2011 | 07:46 AM
trex1928's Avatar
I gave up and carried it to a mechanic. It was the TPS. Thanks for all the help. One other question though. Can you clean the EGR valve or do you have to replace it?
