Transfer Case Question???
I just put a D60 out of an 82 f250 in the rear of my truck. it did not have the speed sensor in the rear so i take it it was in the transfer case well i swapped this rear into my 95 f150 that did have the speed sensor in the 8.8 not the T-case ...... now my question will that transfer case out of the 82 work behind my 300-i6 and 5 speed to regain my speedometer back any input is appreciated ..
Your truck requires an ABS sensor in the rear axle for the speedo, cruise, & RABS to work. Read this caption:
https://www.supermotors.net/getfile/...ster-front.jpg It should be easy to find a D60 with ABS, but you'll need to know how many teeth are on the tone ring to calculate the correct conversion constant for your tire size. You can use any t-case with this mounting pattern: https://www.supermotors.net/getfile/...oltpattern.jpg But the BW1356 is undoubtedly the strongest that will fit in your truck. https://www.supermotors.net/getfile/...56manshift.jpg |
So basically im screwed.... My dana 60 is already bolted in and the gears and locker in place it does not have a speed sensor or anything in the rear and it came out of a 85- older f250.....
Aftermarket speedo with the cable driven speedo oorr swap in a cable speedo from an older dash. Neither are a good fix, but it'll work.
And wheres those picture your promised today haha. |
sorry lol long day....
If you had read that caption, you'd have found this link:
http://www.fordf150.net/forums/viewtopic.php?t=72709 I don't know if he ever got that to work, though. This thread shows 2 methods that work: http://www.explorerforum.com/forums/...d.php?t=300588 Or, you could just find a D60 housing w/ABS & transfer your guts into it. |
