I got my flat bed on my custom f-250
Old Feb 3, 2011 | 11:51 AM
ukv894's Avatar
Originally Posted by Steve83
OK But if you stain & varnish it now, it'll never cup, & never need to be sanded down. Sand in the varnish will provide more grip that lasts longer than steel strips coated with Rhino. Rhino is actually pretty slippery when wet.
I am sure they will end up cupping, I put 7"Wx2"thick red oak flooring down in my cabin and sealed it with gem coat and it cuped all to hell after a year.
I'm not too worried about the oak myself. when the truck is in use, the bed will be also. And I will have the walls and roof on my garage this next year, and it will house my ford.
My Father, and Brother are both master carpenters if they say it will be ok I just take there words for it. If it gives me problems, Ill just cut another tree.
Old Feb 3, 2011 | 11:56 AM
ukv894's Avatar
Originally Posted by bikertrash3531
The truck and bed look awesome. The yellow and black sticks with your "tonka" theme. And I love those old school mud flaps!!! I haven't seen those in a long time!
I had some of them mud flaps about 15 years ago on a Nissan truck. A friend of mine brought them over when he was delivering some old mine belt to use as a front mud flap across the bottom on the radiator support.
He asked me if they where ok for me, I smiled and said, they fit the era of the years in the truck and would be great!
They where free, and get a free laughs.
Old Feb 3, 2011 | 09:53 PM
adrianspeeder's Avatar
Nice turbine rims. What makes your truck a 250 though? I count five lug axles.
Adrianspeeder
Old Feb 4, 2011 | 08:33 AM
ukv894's Avatar
Adrianspeeder
The dana 60's I have laying in the back yard. I haven't quite got that far yet.
There will also be ARB air lockers, front and rear along with a atlas transfer case and airbags on all 4 corners.
Old Feb 4, 2011 | 09:47 PM
Ahh.
How would you do the speed sensor in the rear with a 60?
Adrianspeeder
Old Feb 4, 2011 | 10:45 PM
russo2's Avatar
I wish my wheels were that style, I'm afraid mine won't work with wider tires
Who needs a speed sensor for a basically woods truck right?
Old Feb 4, 2011 | 11:12 PM
Steve83's Avatar
Since I see no slushomatic cooler lines in this pic...
...and he says it's off-road only, he probably doesn't need an ABS sensor (no speedo, no cruise, no ABS).
How 'bout it, ukv? What transmission did you install, and do you want the speedo to work?
Old Feb 5, 2011 | 12:03 AM
russo2's Avatar
The tranny is an m5OD, seen a picture of it in his albums, soooo if he has the what is it bw1345 or 1365 transfer case there's his speedo hook up, right?
And ABS is over rated.
Old Feb 5, 2011 | 10:22 AM
ukv894's Avatar
I got rid of the rear ABS. My truck also don't ware speedo's , lol. J/K I really havent even thought about the speedo yet. Most of the time I use GPS anyways.. I believe it is a Bog Warner 1345, not sure witch one of the 3 I have out there I put in, its just a temp job anyways. But it is working great, and like everything els, I have gone over, and through it.
I have a 4 speed trans, but I put a 5 speed in the truck. I think it will do better with the atlas, and my brother wants to trade me a John deer tractor for my 4 speed.
The truck does have cruise control, for them long halls. It also has a drivers side Air Bag.
Old Feb 5, 2011 | 10:47 AM
russo2's Avatar
The 1345 is the one that would of been stock on a 150 with a sixxer and 5 speed. I'm not sure since yours came from a newer model but mine is cable driven from the transfercase. I'd imagine yours is somewhat electronic.
Old Feb 5, 2011 | 12:25 PM
Steve83's Avatar
If you want cruise, you have to have a working speedo, which requires a working ABS sensor in the rear axle. Read this caption:
russo
Your truck is different - that doesn't apply to you.
Old Feb 5, 2011 | 08:40 PM
russo2's Avatar
I figured the newer truck was more involved. Cruise is over rated, I don't plan on ever fixing mine.
Old Feb 5, 2011 | 10:40 PM
booba5185's Avatar
I didn't even know mine worked, I thought it was broke and I've had the truck for pushing 5 years lol. It works like a charm, but the light doesn't come on, bulb is good, cluster was replaced (not because of this light, because I wanted a tach).
Are the axles the only things to make a 150 to a 250? I thought there was a stronger motor, suspension, brakes, etc. I don't know what you've put into this truck, or what the requirements of a 250 are. What else makes it a 250?
Old Feb 5, 2011 | 10:50 PM
russo2's Avatar
The badges make it a 250...
With the suspension that is under my truck it is badged as a 150 and tagged by the state as a 3/4 ton truck... 250.
But really the f250 would have bigger suspension and brakes and possibly a heavier frame? In these OBS years the body was the same and you could get the f150 motors and bigger motors too.
Also the f250 5 speed was the much better zf5 not the weaker m5od like the 150
Old Feb 6, 2011 | 02:10 AM
Steve83's Avatar
It's easy, but if you don't want it to work...
Originally Posted by booba5185
I didn't even know mine worked.... It works like a charm, but the light doesn't come on, bulb is good...
What are you talking about? There is no cruise light.
No, the frame, brakes, tires, & suspension are also different. Everything else could be had in any chassis: engine, trans, t-case...
