radiator
Old Dec 1, 2010 | 04:15 PM
adtosler's Avatar
radiator
I had a new radiator installed in my 1990 f150.
there is an outlet below the filler neck that my mechanic blocked of with a dead end hose. It started to weep a clear fluid not transmission fluid once the truck got warm is this normal, would it not push into the overflow plastic tank ?
Thanks.
Old Dec 1, 2010 | 08:04 PM
russo2's Avatar
That should be a line leading to your overflow thank. I was told by another member on here to make sure that it is an air tight seal.
If you search through threads I've made recently you might find it.
Old Dec 1, 2010 | 08:31 PM
adrianspeeder's Avatar
No, if it is blocked off, it wouldn't be hooked to the overflow tank...
Adrianspeeder
Old Dec 1, 2010 | 08:58 PM
Steve83's Avatar
Take it back to the guy you've already paid and have him fix it.
Originally Posted by adtosler
...my 1990 f150.
What engine & trans? If you don't know, read this caption:
Old Dec 2, 2010 | 11:50 AM
adtosler's Avatar
So if the block of was leaking slightly it would push antifreeze out?
There is another line to the overflow.
Old Dec 2, 2010 | 07:59 PM
Originally Posted by steve83
take it back to the guy you've already paid and have him fix it.
x2.
