87 f150 smog pump
Old Oct 29, 2010 | 10:02 PM
Tim Clinton's Avatar
Question 87 f150 smog pump
I am looking for procedure info to replace smog pump. Pulley will not turn and whines when started. I have looked in manuals and online.
Thanks for any info.
Old Oct 29, 2010 | 10:21 PM
booba5185's Avatar
You can try spraying some penetrating oil into it before pulling it, that may help breka it loose. I just pulled mine and it's pretty straight forward. Had to move then bel tension to get the belt off (16 mm with a breaker bar for ease), then the bottom bolt attaching the smog pump is right at the front of the oil pan (1/2 inch). For the top bolt, the pulley was in the way so I pulled the pulley off (10mm boltsx3), if your pulley doesn't come off, they you can hit it with a hammer a little bit, just hit it, then turn it a little, then hit it again, etc. You most likely won't have to replace the pump, just clean it and oil it. Once it's out, you'll see 4 bolts holding it together on the back of the pump, take those out and it will seperate, then just clean and oil the bearings.
Old Oct 30, 2010 | 10:57 AM
Thanks for the info.
Old Oct 31, 2010 | 03:41 AM
Steve83's Avatar
Read this caption:
Old Oct 31, 2010 | 03:43 AM
booba5185's Avatar
Damn, I looked for that same caption for a good half hour, but yea follow that.
Old Nov 5, 2010 | 08:49 AM
Thanx for all the info. I have removed the smog pump and will look at it deeper next day off.
