erratic skip 85efi 5.0
I have a problem with a sympton of a miss or skip but it wont set a pattern. I have cleaned injectors, changed fuel filter,new plugs and wires, cap button new pip, newdistributor[napa] . I am looking at the black charcoal box for a possible vacumn leak, I smell gas real strong when I unplug the hose routed from the side of the throttle body. The miss will occur at idle sometimes and at different speeds but I can not make it happen by any type of driving style. Any suggestions? THANKS
I have a miss under load. It sounds similar to op's post.I changed the fuel filter and the problem was reduced. I feel it the most when the engine is cold. If I drive it for an hour it almost goes away except for in fourth gear. if I try to go full throttle accelleration in 4th the stumble returns.
I set the timing exactly at 10 before tdc with the spout removed, the plugs are at 45 thousands. The old ones were squeaky white with a perfect gap. Both sets are autolite platimun. I did route the wires as the diagram explains. Thanks Steve83
Found my problem, I had a bad voltage regulator. Crazy thing though it would never let the battery completely discharge. I just happen to notice that after driving it at night that the start up would start to drag a little. So I checked it with a digital meter and HOT DOG it was weak on its charging .
I finally put an alternator on this truck and now I have probably put close to 1500 miles on her and she seems to run flawlessly, especially for a twenty six year old vehicle. 1985 f150 EFI 5.0 2WD. I appreciate all the help with suggestions of what to do.
Most threads end as a mystery...
