I press the brake and fuse blows & turn signals dont work.
Old Oct 25, 2010 | 09:32 AM
mcnally's Avatar
Hello. I have a 1992 i6 f150 auto. I noticed that 1. my battery was always drained. 2. my turn signals interrmittantly work. 3. I now realized that when I press on the brake pedal the fuse blows. in addition, when checking the tail light sockets the bulbs were lit without pressing on the brake(I checked the switch, its fine).
I disconnected the wiring underneath the back of the truck to see if perhaps a socket was causing it to blow and took the bulbs out and it still blows the fuse when I hit the break.
Any ideas?
Old Oct 25, 2010 | 02:24 PM
Steve83's Avatar
The brake filaments were lit when the fuse was blown??? Or was it the park filaments? Were they full-bright, or dimmer than normal?
Look for aftermarket wiring spliced into the brake circuit, like a trailer connector, or an alarm.
Old Oct 25, 2010 | 08:07 PM
adrianspeeder's Avatar
The two times I've seen this came from a hacked up trailer connector install, and a miswired brake controller.
Adrianspeeder
Old Oct 27, 2010 | 07:13 AM
mcnally's Avatar
problem resolved
After staring at the wiring schematic for what seemed to be days and testing the circuit to ground, I found the problem.
The problem was a grounded positive wire that came from the brake pedal switch to the multi-function switch. So instead of pulling the dash completely out, I ran a new wire and soldiered it in there.
Thanks,
Matt
Old Oct 28, 2010 | 12:46 AM
Steve83's Avatar
I'd be REALLY curious about why/where the original wire shorted. If something was assembled wrong & pinched it, others could soon follow.
