TDC problem/question
Old Apr 18, 2010 | 08:05 PM
G Mc's Avatar
I know the best way to get ones engine to TDC is to remove the valve cover and turn the engine till #1 is on the compression stroke. Is there anyway to find TDC without pulling the valve cover off? I have a 91 f150 5.0. Thanks
Old Apr 18, 2010 | 08:13 PM
StrangeRanger's Avatar
Pull all the sparkplugs
Stuff a wad of tissue paper in the #1 sparkplug hole.
Turn the engine with a wrench on the damper to bring it quickly up to TDC
If it's on the compression stroke, it will (usually) spit the tissue out
Old Apr 18, 2010 | 10:32 PM
G Mc's Avatar
thanks strange ranger. My truck isn't starting and I am trying to diagnose, just needed this info for future reference. It is turning over but will not start. Thanks again.
Old Apr 19, 2010 | 03:01 AM
Have you checked for spark and fuel?
Old Apr 19, 2010 | 11:02 AM
G Mc's Avatar
checking for spark today ...seems like the problem may be somewhere in the ignition portion. Fuel has to be there because you can smell it and when I took the plugs out they smelled of fuel. So like I said, checking spark in probably an hour, I will get back and let you know how it goes ...thanks glc......annnnnnnd there's no freaking spark, any suggestions on what to do next? I am going to search past listings but advice is appreciated thanks to all.
Old Apr 19, 2010 | 01:11 PM
ymeski's Avatar
Coil, TFI module, or PIP sensor (stator).
Old Apr 19, 2010 | 05:52 PM
G Mc's Avatar
The coil, plug wires, distributor cap are all brand new for the truck, so I will check module next then the pip sensor. Thanks ymeski.
Old Apr 22, 2010 | 11:51 AM
G Mc's Avatar
strangeranger do I have to pull all the plugs or can I do that trick with just pulling the #1?
Old Apr 22, 2010 | 12:47 PM
You'll never turn the engine by hand with plugs in it.
Old Apr 22, 2010 | 02:47 PM
ymeski's Avatar
Gee, great time for a compression check too!!!
Old Apr 22, 2010 | 05:44 PM
G Mc's Avatar
Ok thanks guys, I had it set perfectly then it was late and i was tired and freaking mounted the distributor wrong. So now I have all new plugs, wires, cap, rotor, module and pip sensor. Just gotta reset tdc and then hopefully it will fire. Thanks again for everythign guys
Old Apr 23, 2010 | 01:16 PM
G Mc's Avatar
FINALLY got her running!! First time in 2 years. That baby was extremly loud with the LT's on there and no exhaust. Just wanted to thank all you guys for the help!!! I will try to post some videos when I get the exhaust on, money allowing, I am hoping some time next month. Thanks again guys!
Old Apr 26, 2010 | 09:22 AM
aswaff400's Avatar
i could turn my old 302 over by hand with all plugs in... can you say no compression?!
